While using 2011, my coworkers and I setup a cenrtally located styles library on a server that we linked to which allowed each of us to add/edit/use the same styles. Now that we have implemented 2012, we cannot figure out how to implement this styles library into 2012.
Any help here would be much appreciated.
Mike
Solved by -niels-. Go to Solution.
Did you migrate your style library using the style library manager?
(start - all programs - autodesk - autodesk inventor 2012 - tools)
If you have, make sure you've set the path in the application options.
Hope this helps.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Ahh.... Thank you. Who would have thought Autodesk would have yet ANOTHER external program for performing yet ANOTHER seamingly trivial task. Way to go ACAD! Had to do it several times and save in several different locations before I got it to work. It also transferred my custom text but did not see the need to keep it where I had been using it in 2011. Oh well...
THANKS AGAIN!
