I you don't have too much clutter in your directories, just zip up the
files (with directories) and copy to a CDRW or a Compact Flash or?? then
unzip / copy at the target location. If your project is set using
relative paths and you have matching library locations at each end,
simple Windows copy is all you need. Pack N Go can be useful if you
have a lot of junk in your directories.
If you are running Semi-Isoloated, you could "Check-out" the tree then
copy the entire contents of you Workspace to CD.. for transport.
matty_t wrote:
> Hiya all,
> Just recently started using Inventor as part of my job... would be gr8
> if sum1 could suggest the best way to transfer projects/ files from my
> home machine to my work machine as i hope to do sum work over the
> weekend at home... thought about streamline but but comps. only have
> dial up... any suggestions????
> Thanx,
> matt
