As the title states, replaced component in assembly and now ipn trails are no longer on center. Is there anything that can be done besides a re-explode?
FWIW, currently using Inventor 2014.
Thx...Shawn
If the replace was done after the original component was "Save Copy As" it should replace as normal. If the component was swapped out for another component previously built then locate the first sketch of the part (new file for IPN) and constrain it to the origin "center point". Save the part file. See if this will shift the origin trails in the IPN file.
Don
