Hello everyone,
I've got a quick one for you guys. So I've started utilizing parts with exported parameters more frequently at work. It works great but there is one thing I would need to change that pretty well perfect it.
Say I have a part which is 40 feet long. If I were to call this out in my drawing (using a leader text for example), my company standard would have it say "<description> x 40'-0" LG <description>". However, if I export the parameter and use it in the leader text, the result I get is "<description> x 40' LG <description>". I know that they provide the same information but the less "different" something I'm trying to integrate into our normal practices is, the better.
The obvious benefit is not having a leader text call out something in text, but rather to have it reflect the actual dimensions in the part file. I'm just wondering if there is a way to get that format specifically. The way I'm used to formatting them in the part file parameters dailog is as shown below:
And as you can see, "Trailing Zeros" cannot be applied to this parameter.
Any thoughts?
Just gave it a try. Didn't seem to change anything in the leader. Could this potentially be because the leader contains more than one parameter from the part file?
I've found, in the meantime, that I can work around this issue but having my feet and inches exported seperately. Though I still feel this is a bit clunky. It does get the job done.
