Inventor Forum
Track meshing
2 REPLIES 2
Tracker2012
304 Views, 2 Replies
Track meshing
I am trying to optimize a sprocket drive but need help simulating the rubber belts holding the drive section together.
Any ideas?
Have access to Several autodesk products. I was able to get a short simulation in Inventor but i need a more accurate one.
I have attached a pdf file showing the basic idea.
2 REPLIES 2
Tracker2012
in reply to: Tracker2012
i know have a full loop assembly with a drive sprocket and two wheels. The fist run it ran but the belts start to bunch up. So i put a spring between the two wheels and it shows some movement put seems to bind up and stop moving. If any one thanks they can help i can send them the files.
JDMather
Do you have the book by Wasim Younis?
