Torsion Spring:
Hi. Has anyone had any success with torsion springs? I have a small torsion spring with two axial legs that we have used for 30 years. Design Accelerator would not accept the positioning(?) angle of the legs, so I had to settle for the closest model. the spring legs are 90 degrees apart loose. Total travel is 120 degrees, with 30 degree pre-load position from loose. I need to position the spring-driven component, and the spring does not 'give'. The spring is marked 'flexible', yet the only instance of 'Adaptive' I can see is greyed out. I have not been able to make the torsion spring adaptable, and flexible doesn't appear to do anything. Any help would be most appreciated.
Best regards,
Geo.
