Inventor General Discussion
*Dotson, Sean
Message 11 of 21 (47 Views)
Re:
12-07-2002 08:43 PM in reply to: *Hinterhoeller, Richard
That's exactly what it is. Juts keep in mind it can blow up an assy real
quick. It may give you constraint errors at a point no where near the part
that changed tolerances. Juts keep it in mind...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Cory McConnell" wrote in message
news:87B7959E132DA5DFDF3357857B048B73@in.WebX.maYIadrTaRb...
> I just assumed that the yellow circle meant the dimension is modeled at
> nominal; the + models the dimension at its max; the - models the dimension
> at its min. I think this may be half useful for checking for tolerance
> stack interferences. Although, I haven't tested my theories
thoroughly.
> Cory McConnell
> BJ Pipeline Inspection
> "Richard Hinterhoeller" wrote in message
> news:3DF28E07.10808@hfx.eastlink.ca...
> > Joe:
> > Thank you. I'd love to know how all of you figure these things out.
> > Do you have any idea what the yellow circle, + and - mean?
> > Richard
> > Joe Bartels wrote:
> > > In the Parameters dialog box you can pick the value in the Equation
> column.
> > > When the value is selcted the arrow pulldown menu will appear and you
> can
> > > set the tolerance here as well.
> > > The Tol. column is used to quickley set the dimension at its min, max,
> and
> > > nominal field.
> > > I agree that it should be easier to find information through the help.
> It's
> > > there if you know what to look for, but there's no tutorials for it.
> message
> > > news:3DF27F6C.6080504@hfx.eastlink.ca...
Message 12 of 21 (47 Views)
Re:
12-07-2002 10:34 PM in reply to: *Hinterhoeller, Richard
Cory an Sean:
Thanks. As I was falling asleep last night it occurred to me to
experiment with exactly what you describe. I certainly hadn't thought
it through to the point of causing constraint errors so that heads-up is
appreciated.
Richard
> Sean Dotson, PE
> thoroughly.
>>Cory McConnell
>>>Joe:
>>>Richard
>>column.
>>can
>>and
>>>>nominal field.
>>It's
>>message
Message 13 of 21 (47 Views)
Re:
12-07-2002 10:39 PM in reply to: *Hinterhoeller, Richard
Sorry all for the grumpy tone in this thread. I can't imagine it having
anything to do with working on a Saturday evening.
I'd like to make it clear that I'm glad the tolerance functionality has
been added to IV and I hope the developers have plans to polish up the
interface a bit.
Richard
*Dotson, Sean
Message 14 of 21 (47 Views)
Re:
12-07-2002 11:49 PM in reply to: *Hinterhoeller, Richard
That's an important point to remember. I was a very big critic of what was
put into R6 as tolerances but I have toned down as I have used it more. You
have to start somewhere and I know this is just the first step. You are
probably feeling the same things.
Sean Dotson, PE
news:3DF359AE.1050503@hfx.eastlink.ca...
> interface a bit.
> Richard
Message 15 of 21 (47 Views)
Re:
12-08-2002 12:46 AM in reply to: *Hinterhoeller, Richard
Sean:
I think what tipped me over the deep end on this was the lack of help
available in the help screen.
I managed to uncover paragraph after paragraph about what tolerances are
and how useful they are, but no instructions on how one use them within
the IV environment.
Richard
> Sean Dotson, PE
*McConnell, Cory
Message 16 of 21 (47 Views)
Re:
12-08-2002 01:49 AM in reply to: *Hinterhoeller, Richard
When I sat down to use Inventor the first time (R4 Trial Version), I opened
up help looked at a few things became totally confused, and closed it.
haven't had it open since. When R6 came I opened up the manual, just for
fun, and discovered it was quite a joke in its own right. Weldments
aren't even mentioned.
Cory McConnell
news:3DF37780.1060607@hfx.eastlink.ca...
> Sean:
> the IV environment.
> Richard
was
You
> > Sean Dotson, PE
*Crain, Ron
Message 17 of 21 (47 Views)
Re:
12-08-2002 02:27 AM in reply to: *Hinterhoeller, Richard
"Sean Dotson" wrote in message
news:FD54CB4DA8E05CD41E6ED1D813273FB0@in.WebX.maYIadrTaRb...
> They do need to work on the way tolerances are passed to the IDW however.
> Right now unless you use "Get Model Dims" which I think only <1% of
people
> do (I certainly don't) it's several clicks to get them to show up
> correctly..
Sean, are you saying that you can get tolerances to display if you don't use
"Get Model DIms"?
How?
*Dotson, Sean
Message 18 of 21 (47 Views)
Re:
12-08-2002 08:01 AM in reply to: *Hinterhoeller, Richard
Yes but it's a difficult (IMO) process. I'll outline it for everyone
tomorrow.
Sean Dotson, PE
"Ron Crain" wrote in message
news:smileyvery-happy:A59CD1C512D10E83925A32A990BD815@in.WebX.maYIadrTaRb...
however.
> people
> > correctly..
use
> "Get Model DIms"?
> How?
*Dotson, Sean
Message 19 of 21 (47 Views)
Re:
12-08-2002 09:17 PM in reply to: *Hinterhoeller, Richard
You know what Ron. I was wrong. I was thinking about hole notes. That you
can do. Regular dimensions are a no go. Which is why I find them useless
in the state they are now. As I said before I understand they need to start
somewhere but right now they are useless..
Sean Dotson, PE
http://www.sdotson.com/faq.html
however.
> people
> > correctly..
use
> "Get Model DIms"?
> How?
*Crain, Ron
Message 20 of 21 (47 Views)
Re:
12-08-2002 10:50 PM in reply to: *Hinterhoeller, Richard
Useless, yes. If only they allowed selective "get model dimensions".
news:BC303895943742BAD0005D066A155905@in.WebX.maYIadrTaRb...
start
> Sean Dotson, PE
> however.
> > people
> > > correctly..
> use
> > "Get Model DIms"?
> > How?
Announcements
Need installation help?
