Inventor General Discussion
Active Contributor
Myles1
Message 1 of 3 (181 Views)
tolerance precision inv 2011
181 Views, 2 Replies
07-27-2012 09:18 AM
I am trying to change the precision of my tolerance values, but nothing I do in the "Edit Dimension" window on the "Precision and Tolerance" tab seems to have any effect on the dimension on my drawing.  If I change the tolerance methon in the Edit Dim window, that updates, but not the precisionof either my Primary Unit or the Primary Tolerance.
I need to be able to change the tolerance precision for certain parts.
I tried creating a new dim style, with the precision I wanted in the dim style itself, but that also didn't work.
Any ideas?
New Member
thomasloganinman
Message 2 of 3 (142 Views)
Re: tolerance precision inv 2011
11-06-2012 04:07 PM in reply to: Myles1
select the dimensions that has the tolerance and right click it. select properties and scroll down to the tolerances section. there is a line labelled "Tolerance Precision" and that is what you need to change. the tolerance has an automatic 4 decimal place precision so that's how you change it. good luck!
*Pro
sbixler
Message 3 of 3 (124 Views)
11-07-2012 04:17 AM in reply to: Myles1
Inventor doesn't behave this way for me, so that probably means that I'm not understanding what you're trying to accomplish and how you're going about it.  Can you post a screenshot of the Edit Dimension dialog?  You're working in a drawing, I assume, not a model?
