Inventor Forum
Tolerance Method
5 REPLIES 5
844 Views, 5 Replies
Tolerance Method
While looking at the different tolerance methods, I see a couple called MIN and MAX, which just tack these words to the end of the dimension. Is there a way to customize the tolerance methods to add suffixes or prefixes to dimensions, such as TYP or 2 PLCS or something like that, so that I can minimize my detailing time. Yes, I am THAT lazy.
vandargo
5 REPLIES 5
mcgyvr
yes.
open your idw template file. go to format..style and standard editor...from the left hand side of the dialog box find your dimension style...then go to the notes and leaders tab. modify the appropriate note format and save.
Thanks mcgyvr...
I understand how to modify the notes & leaders stuff, but I would like to know if I can modify the tolerance methods in a similar fashion. If you go to the same area, just go to the tolerance tab instead, and select from the METHODS drop down, this is the list I would like to modify. That way, when I create a dimension, I can just go the drop down in tolerance methods and select what I want my suffix to be (In this case, TYP), as I would if I were to create a MIN or MAX or reference dimension.
Hope this clarifies.
vandargo.
Hi vandargo,
There is no way to edit the tolerance
methods.
Tim
mcgyvr... I understand how to modify the notes & leaders stuff, but I
were to create a MIN or MAX or reference dimension. Hope this clarifies.
vandargo.
Has there been any progress made by Autodesk on this since the last post?
Chad
Maximus423
An Autodesk responsible can answer if you have add the possiblity since 2009 to add a "Tolerance method"? I just want to know if it is possible because in the other case, I create a new note + create a new dimension only to add a line under my dimension according to the ISO norm: ISO 129:1985 (an underline dimension).
Thank you,
Max
