Inventor Forum
To scribe lines on a cylinder
2 REPLIES 2
1668 Views, 2 Replies
1. I would like to scribe number of lines in axial direction & around the circumference of a cylinder
2. Secondly, I want those lines to be visible on .idw file so that I can print my drawing
Sample image attached.
Thanks.
2 REPLIES 2
hosford
just extrude a small cut and array it around the centerline, then revolve a small cut and array it along the length
Thaddeus Hosford
NUC9i9QNX i9-9980HK, Win 10 Pro 64
Nvidia GTX 1650
Inventor 2021
stephenrottloff7259
To get accurate lines on a drawing view, that are controlled within an ipt, you need to use surface modeling.  You project surfaces to the cylinders body, which are created on workplanes that you can move or control.  I attached a screen capture of the idw model tree.  In the idw, you need to right click the ipt and select include all surfaces and on 3D scketches right click and select include.
Hope this helps.
Stephen R.
