As iLogic assemblies grow..is it better to layer the parts/assemblies in different assemblies? I am trying to create a grain hopper with filghting, flighting tubing, bearings, shafts, stands with bearings, etc... I think you get the point. I am going to have either several different parts or several different assemblies and I would like to know the BOP (Best Operating Procedure) for this type of assembly.
Ultimately, I want to be able to use a form and just select a hopper and have everything change. I have done it with the plain hoppers already but that was just iLogic parts into an assembly and now it’s time to get complicated….LOL
Solved by Breeze104. Go to Solution.
Solved by MjDeck. Go to Solution.
If you have a large number of parts, then it's probably a good idea to use subassemblies.
