Without going full bore into skeletal modeling
http://www.sdotson.com/freetut/introduction%20to%20skeletal%20modeling.pdf
http://www.mymcad.com/KWiK/iMaster/iMaster.htm
you could take the first step and place all your parameters into a file.
The derive this file into new files and create your parts from there. Any
changes to the first file will propagate down the line to your derived part
files. Then there is one place for all parameters to exist. The
disadvantage is that you cannot refer to these parameters in the assy itself
without a few workarounds.
http://www.sdotson.com/freetut/linked%20&%20embedded%20parameters%20part%20t
hree.pdf
Or you can wait till December and come see me at Autodesk University speak
on this very subject.
http://tinyurl.com/ioyk
Sean Dotson, PE
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Tim Dougherty" wrote in message
news:94CCE17C6610E07CAFC37A38A5D4B339@in.WebX.maYIadrTaRb...
> Well, I'm about to start a final design on a small assembly of mine. A
> couple sonic welded components with an assembled sub assy.
> I started my design using much adaptivity. Since the design was fresh, a
lot
> of the geometry that was used in adaptivity got swallowed and I lost many
> references along the way. I didn't like that. Although now that I know I
am
> close to final design and going back through my geometry, maybe it will
work
> better for me this time. I also found the possibility of deriving my parts
> from a part file full of global parameters to be interesting......that
might
> work, but I'm concerned about that parameter file and what might happen to
> it down the line. Next we arrive at linking an excel file to all my parts.
> Seems simple and I'd be working from one sheet. this might be nice as I
will
> be applying drafts and such to my parts this time. What would be nice is
if
> I could embed my xls in the assembly file and pull all my parameters from
> that one file, no external xls. But, it doesn't seem to work for me. Am I
> wrong in assuming if I use a stand alone xls that I will need to do a link
> operation to each and every part ? It sure would be nice to be able to
pull
> it from the assembly. Then I'd know it would never go away.
> any thoughts ?
> tia
