Inventor Forum
To bend or not to bend, That is the question!
7 REPLIES 7
Message 1 of 8
175 Views, 7 Replies
Many times I am faced with the challenge of creating a complex part that requires the use of tools on the “Part features” toolbar and the “Sheetmetal features” toolbar. I know that if I start with a Sheetmetal part I can toggle to the Part feature toolbar and then back to Sheetmetal, but can I go the opposite way? I would like to use the Sheetmetal “Fold” tool on a non sheet metal part. Is this possible? If not, is there a way to change permanently a “Part” to a “Sheetmetal” part? (frustrated, I just want to bend the darn thing!)
TIA Tom..
7 REPLIES 7
Message 2 of 8
Never mind, I just found it under the applications pull down.
Thanks anyway!
Message 3 of 8
It's our pleasure
We like to tknow that just thinking the answer we can beam it back through the internet as in
Inspiron (neutral I particle) that will come out of your monitor, strike your frontal lobe at the
correct angle to cause a brainwave to occur.
John Bilton
Message 4 of 8
My Company Standard.ipt file is a my standard sheet metal file which is then
reverted back to a normal (I.a. non sheet metal part) and then saved as a
template. Saves having to import the Sheet Metal Styles if I ever change my
mind about a part half way through.
Cheers,
--Rob Singlehurst
"John Bilton" wrote in message
news:52C5F6E4824D10C99DBECB41EC246BD6@in.WebX.maYIadrTaRb...
> It's our pleasure
the internet as in
> John Bilton
Message 5 of 8
And it keeps the sheetmetal styles info? What a great idea.... I have struggled with the
dropdown to start new files not having the sheetmetal template. 90 + % of my files are
sheetmetal, and I had tried renaming the sheetmetal template to standard, but then
realized my iParts were being built from it also.
I will have to give you method a try .... thanks.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Rob Singlehurst" wrote in message
news:0D213F7A5A7AA2C78F14CB4AE2471660@in.WebX.maYIadrTaRb...
Message 6 of 8
Yep works fine.
Cheers,
--Rob Singlehurst
"Kent Keller" wrote in message
news:330EDB7E4FAD7ECC9900B5DB88FFAC83@in.WebX.maYIadrTaRb...
struggled with the
of my files are
but then
> Kent
then
a
change my
Message 7 of 8
What do you mean "reverted back to a normal" (I.a. non sheet metal part)? Also how would you "import the Sheet Metal Styles" into a non sheet metal part file?
Message 8 of 8
You can switch modes in the Application pulldown, and you can import styles using Format
.... organizer
Kent
"tmalinski" wrote in message news:f12c4c8.5@WebX.maYIadrTaRb...
