I have three customised sheet templates for metric, imperial and metric imperial duel dimensions. The basic layout of these title blocks are the same EXCEPT for the text colours. When I first created these new templates I over-rode the default text colour as well as setting a different specific size text size for A4,A3,A2,A1 and A0 title blocks within the title block edit to be BLUE for IMPERIAL and RED for METRIC
So today I changed the colour and size of the Notes and Labels Text in style editor saved these but now when I use the two template's with the different colours they text is now the same colour and size as that in the recently changed and saved style.
I was of the assumption that If I manually over rode the colours and size that text in a title block editor that these would stay set at that colour and size regardless of any changes made in the style editor with regards to the text settings. This was the case in IV2013 in which these templates were created but is seem not to be in IV2014.
Is any one else seeing this behavior with there customised title- lock that were created in a previous version of IV ????
I am still in 2013, but I do know if you change this in the template, every drawing using that template will reflect the changes, but if only done in a specific drawing, these styles changes only reflect in that specific drawing.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I thought so as well, I'd check if any SP's and Updates to SP's address this issue. One should always be current with all SP's and Updates.
(EIDTED @ 12.42 BST)
All SPs and update installed up to SP2 Update 1 - 14/06/2014, not seen any notices of any further SPs, or Hot-fixes. I'm going to have a look as check though.
I currently going through all the templates manually changing the text overrides, this time there sticking regardless of any changes to the mother text settings.
Bit of an unnecessary monotonous time consuming task though, 3 different templates each with 4 different sheet sizes and 12 section and two lots of text per section.
Biggest bug-bear with this is that when I over-ride a default text setting, even if its a note in a drawing to either make it bigger or a different colour, it is over-riden for specific reason, in this case the text size is to big for the title-block with out the title-block taking up to much space. If I over-ride somthing I expect that over-ride to be hounered at all times, more so with a correctly fornatted and saved template file.
And now another when I select the text to chnge the colour, going through the appropraate actions, I then get this error :-
Inventor seems to think I selecting a dimention to chnge for some reaosn, when I not, so now I've got to delet one of the dims to be able to select and change the text.
So, basically you are looking for the changes in the styles to be grandfathered into all drawings forward and backwards. Never known Inventor to do that.
I know, I wouldn't want that to happen in my situation. That would be unsettling to me and cause a lot of cautious. Like I said before, and like it seems you have done already, make these changes in the template.
"So, basically you are looking for the changes in the styles to be grandfathered into all drawings forward and backwards" ?????? WHAT ????
I'm just looking for the OVER-RIDE to be honored in 2014 in the same way as they were honoured in 2013 ie When using 2013 I could over-ride the set style from 10mm to 3mm in the title-block by "Select Text - RMB - Edit Text" and making the changes then I'd expect" that over-ride, once I click "YES" to save the changes in the title-block, to stay set a that size and not be affected by any changes made out side the Title-block editor. The whole idea of an over-ride is just that make changes with out affecting anything else over that that particular piece of text.
