Inventor Forum
Title Block
4 REPLIES 4
maw316
227 Views, 4 Replies
Title Block
I created my own title block as a standard template for company drawings. I recently got a new computer and loaded Inventor 2008 and have been working with it. I came across an error message when I choose to edit the title block. The message states "Edit Title Block Template: Problems encountered while executing this command, Could not insert Object." I have tried to save the template under my local drive and I can edit it there, but I can't seem to figure it out. Any advice?
4 REPLIES 4
bunnifer451
in reply to: maw316
Have you tried using the Drawing Resource Transfer Wizard?
Inv_kaos
in reply to: maw316
Have you migrated the actual template and saved it as 2008?
Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful.
Stew, AICP
Inventor Professional 2013, Autodesk Simulation Multiphysics 2013
Windows 7 x64 Core i7 32GB Ram FX2000
Inventor1
in reply to: maw316
Do you have an image (.bmp, .jpg, etc.) in your title block? Thay can cause trouble.
Daniel
in reply to: maw316
Does your title block contain an image file (logo, bmp)? If so, you
may need to reinsert this object. If this is not the problem, can you
please post your files or email them directly to me at
tanya.garner@autodesk.com.
Thank You,
Tanya Garner
Inventor QA
