Inventor Forum
Title Block Prompts?
25 REPLIES 25
Message 1 of 26
990 Views, 25 Replies
Hi, I was wondering if there is a way to arrange the prompt entries of my
template to come up in the order I want?
or do I have to create them in the order I want cause that would sorta (Edited by moderator)?
Jesse
25 REPLIES 25
Message 21 of 26
the only problem I see with that is in a production environment. Notes and
other production information on drawing needs to get updated at times
causing a rev change without any model changes. You wouldn't want to have to
rev the model without a for no reason. Production Vs engineering
(prototype) documentation is the real issue controlling how you handle your
revisions.
msk
Message 22 of 26
R6 introduced it. See what you get for missing a release
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Dave Hoder" wrote in
message news:B2BBD5A71DDCF517B8A77A71D2BB0D20@in.WebX.maYIadrTaRb...
> THANK YOU SEAN!!!!!
> Has that always been there or did I miss it on the v6 upgrade?
> Dave Hoder
> Product Design Engineer
> idX Seattle
> www.idxcorporation.com
> "Sean Dotson" wrote in message
> news:4C5B47B86F2ED212B56B799CD004DF4D@in.WebX.maYIadrTaRb...
> > In your template go to Tools>Document Settings>Drawing Tab.
> > About 1/2 way down under Custom Property Source select your part
template
> > file. Check copy model properties and then Click on Properties and
> select
> > the custom props to bring over.
> > In your titleblock select Custom Properties - Model and select the
linked
> > properties.
> > Sean Dotson, PE
> > "Dave Hoder"
wrote
> in
> > message news:ACEC73594C3070B611DAFEBE8E294FA7@in.WebX.maYIadrTaRb...
> > > Oops, I was thinking of bringing in a custom property from a part to a
> > title
> > > block. Different subject I think.
> > > Dave Hoder
> > > idX Seattle
> > > "Brian R. Iwaskewycz" wrote in message
> > > news:CF7921637662DAE489A267639211B31F@in.WebX.maYIadrTaRb...
> > > > Easy...
> > > > Go to the Custom tab of the iProperties of the .idw file, and add
> custom
> > > > properties as needed.
> > > > In the title block, add a property field. In the Type drop-down,
> select
> > > > "Custom Properties - Drawing", and select the custom property you
> > created.
> > > > "Dave Hoder"
> > wrote
> > > in
> > > > message news:97D92F124AFB541177604112DDF43D31@in.WebX.maYIadrTaRb...
> > > > > How do you get custom properties into a title block? I thought
this
> > was
> > > > only
> > > > > possible with a vba routine.
> > > > > Dave Hoder
> > > > > idX Seattle
> message
> > > > > news:A839EE1B1BC90CFBED8F8E75AE8565B1@in.WebX.maYIadrTaRb...
> > > > > > Everything else should (again,
> > > > > > IMHO) be obtained from either the file properties or custom
> > > properties.
Message 23 of 26
I disagree. Even if I make a change to a print only (maybe a weld notation)
I rev the model.
IMO, the model is the master. All info is based on the model. So you rev
the model even if no "physical" changes are made.
Sean Dotson, PE
"Mark S. Klein" wrote in message
news:8A6A58E546D400A760EE580A164D63D8@in.WebX.maYIadrTaRb...
and
to
your
> revisions.
> msk
Message 24 of 26
ROTFLMAO
Sean Dotson, PE
"Brian Corbin" wrote in message
news:A9295971BE12532C979FBD37276CDFAC@in.WebX.maYIadrTaRb...
> Yeah Hal, but do you do Beta Testing? 😉
> Brian
> "Hal Gwin" wrote in message
> news:4A131F8D87E922FFF2B25058FC8246F1@in.WebX.maYIadrTaRb...
> > I'm cheap and easy.
> > Sean Dotson wrote:
> > > BTW, closing in on the new version. Will need some beta testers in a
> week
> > > or two.
> > Hal Gwin
> > Mechanical Designer
> > Xenogen
> > W2K SP4
> > Dell Precision 650
> > Dual 2.66 GHz Xeon
> > 1.5 GB DDR
> > Quadro4 900 XGL
> > nVidia 6.14.10.4472 w/registry update
> > Dell UltraSharp 19" LCD
Message 25 of 26
"Laugh it up fuzz ball."
Sean Dotson wrote:
> ROTFLMAO
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
Message 26 of 26
Brian,
I agree with you. The problem I have is that I can't get some of the
properties of the model to work.
For example: Description, Designer and Part Number work fine
Project and Engineer don't work
I have tried these several times and I can't seam to get them to work.
David Lloyd
> I agree. IMHO, the only thing that should use prompted entries is
something
> that could be different on two separate sheets within the same .idw file
> (like scale and the drawing description). Everything else should (again,
> IMHO) be obtained from either the file properties or custom properties.
> news:5FC5675C70AAC4C8A15ADC9132FC9A84@in.WebX.maYIadrTaRb...
> > you might try using custom properties instead, that way it doesn't
matter
> on
> > order and you can also have the ones that don't change every time
> preloaded.
> msk
