In your template go to Tools>Document Settings>Drawing Tab.
About 1/2 way down under Custom Property Source select your part template
file. Check copy model properties and then Click on Properties and select
the custom props to bring over.
In your titleblock select Custom Properties - Model and select the linked
properties.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Dave Hoder" wrote in
message news:ACEC73594C3070B611DAFEBE8E294FA7@in.WebX.maYIadrTaRb...
> Oops, I was thinking of bringing in a custom property from a part to a
title
> block. Different subject I think.
> Dave Hoder
> Product Design Engineer
> idX Seattle
> www.idxcorporation.com
> "Brian R. Iwaskewycz" wrote in message
> news:CF7921637662DAE489A267639211B31F@in.WebX.maYIadrTaRb...
> > Easy...
> > Go to the Custom tab of the iProperties of the .idw file, and add custom
> > properties as needed.
> > In the title block, add a property field. In the Type drop-down, select
> > "Custom Properties - Drawing", and select the custom property you
created.
> > "Dave Hoder"
wrote
> in
> > message news:97D92F124AFB541177604112DDF43D31@in.WebX.maYIadrTaRb...
> > > How do you get custom properties into a title block? I thought this
was
> > only
> > > possible with a vba routine.
> > > Dave Hoder
> > > idX Seattle
> > > news:A839EE1B1BC90CFBED8F8E75AE8565B1@in.WebX.maYIadrTaRb...
> > > > Everything else should (again,
> > > > IMHO) be obtained from either the file properties or custom
> properties.
