R6 introduced it. See what you get for missing a release
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Dave Hoder" wrote in
message news:B2BBD5A71DDCF517B8A77A71D2BB0D20@in.WebX.maYIadrTaRb...
> THANK YOU SEAN!!!!!
> Has that always been there or did I miss it on the v6 upgrade?
> Dave Hoder
> Product Design Engineer
> idX Seattle
> www.idxcorporation.com
> "Sean Dotson" wrote in message
> news:4C5B47B86F2ED212B56B799CD004DF4D@in.WebX.maYIadrTaRb...
> > In your template go to Tools>Document Settings>Drawing Tab.
> > About 1/2 way down under Custom Property Source select your part
template
> > file. Check copy model properties and then Click on Properties and
> select
> > the custom props to bring over.
> > In your titleblock select Custom Properties - Model and select the
linked
> > properties.
> > Sean Dotson, PE
> > "Dave Hoder"
wrote
> in
> > message news:ACEC73594C3070B611DAFEBE8E294FA7@in.WebX.maYIadrTaRb...
> > > Oops, I was thinking of bringing in a custom property from a part to a
> > title
> > > block. Different subject I think.
> > > Dave Hoder
> > > idX Seattle
> > > "Brian R. Iwaskewycz" wrote in message
> > > news:CF7921637662DAE489A267639211B31F@in.WebX.maYIadrTaRb...
> > > > Easy...
> > > > Go to the Custom tab of the iProperties of the .idw file, and add
> custom
> > > > properties as needed.
> > > > In the title block, add a property field. In the Type drop-down,
> select
> > > > "Custom Properties - Drawing", and select the custom property you
> > created.
> > > > "Dave Hoder"
> > wrote
> > > in
> > > > message news:97D92F124AFB541177604112DDF43D31@in.WebX.maYIadrTaRb...
> > > > > How do you get custom properties into a title block? I thought
this
> > was
> > > > only
> > > > > possible with a vba routine.
> > > > > Dave Hoder
> > > > > idX Seattle
> message
> > > > > news:A839EE1B1BC90CFBED8F8E75AE8565B1@in.WebX.maYIadrTaRb...
> > > > > > Everything else should (again,
> > > > > > IMHO) be obtained from either the file properties or custom
> > > properties.
