Inventor Forum
title block options
1 REPLY 1
marcin.blaszczyk
305 Views, 1 Reply
title block options
Hi once again,
I have two questions:
1) first one is not exactly about Inventor: how do you describe undefined surface roughness in your companies? are you adding surface roughness sign in right top area of sheet or are you including this into title block/drawing table? are you using surface sign or you are only specifying e.g "undefined surface roughness: Ra=3.2" ?.... can you post some samples?
2) question about editing title block: what is the best method to put surface sign into table? see attachment: I would like to have a possibility to put original inventor surface sign into table but it's grey in sketch mode, jpg is the only option here?
1 REPLY 1
-niels-
in reply to: marcin.blaszczyk
I can't answer your first question, since we hardly use the surface symbol on our drawings, the people in the shop know what to do and it's not critical information for our products.
But for your 2nd question, i found that the font "GENISO" holds the surface symbol. (though it's the symbol for square root actually)
Just check windows's special characters tool.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
