I am trying put drawing numbers on my drawings. The drawing number is "019-02-00038-x" where "x" is the page number in the set of drawings. How do I set this up? Every time I try to change "x" it changes it for the entire set of drawings.
I'm working with Inventor 2014.
Solved by Cadmanto. Go to Solution.
It seems to me that in your "Edit Definitions" of your titleblock you shold be able to add something like this.
as an extention to your main part number.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
