A limited selection of Inventor default Title Blocks combined with comments from users in need of a Title Block that offer a more streamlined solution for individual company needs urged me to design the attached Title Block. The Title Block & Border was designed for our company’s specific needs, some information may not suit your preferences, please feel free to change or alter the design to your preference. Constraints were kept to a minimum to simplify edits by the user. The provided Title Block & Border was designed in Inventor 2011 for an ANSI B (11 x 17) sheet size. I have provided a PDF drawing for an overview of the design as a reference prior to download. In view of numerous comments over the internet and mixed emotions of Autodesk Inventor’s default Title Blocks, I feel compelled to share our Title Block with others. Hope this will be of help!
Best wishes,
Gordon van Ekstrom, Chairman / Co-Founder
GDK Technologies, Inc.
Ps. To edit the text: Right-click on ‘Border’, ‘TITLE’ or ‘REVISION HISTORY’ in the Model Browser to select the intended text to edit – select edit definition, then right-click on the actual text to edit – select Edit Text, edit the text - OK, right-click again in a neutral area of the drawing and select ‘Save title Block’ or ‘Save Border’. Don’t forget to save again inside Inventor or your changes may be lost!)
Solved by DevinCurrie. Go to Solution.
