Inventor Forum
Tilted pipe cutout in plate
11 REPLIES 11
Message 1 of 12
613 Views, 11 Replies
Hello, Please find the attached drg. There you will see a nozzle (pipe) projecting from the plate (it has 2 angular dimension). The pipe is 406 mm OD i am not able to make the cutout in the plate (as the cutout is to be made first in plate ). Thought that inventor can do it , but i am new to inventor, some how not able to extract from it. Step by step procedure appreciated. many thanks in advance.
11 REPLIES 11
Message 3 of 12
I was not adding attachment.
it was an pdf file
Message 4 of 12
add attachment is not working!!!!!!!!!
Message 5 of 12
in reply to: cbenner
add attachment not working
Message 6 of 12
Paul-Mason
If you file/s won't attached try one of these
1) Check that Internet explore IS NOT in compatibility view and resend
OR
2) use GOOGLE CHROME to attached files ( this is usually the best option.
3) The file is to big zip it and try again.
From personal experience IE11 has some, well quite a few, compatibility problems with this and other sites as bid IE10 but most of those were fixed.
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Message 7 of 12
JDMather
3 solutions
1. multi-body solids
2. derived components
3. edit in context of assembly and Copy Object surface for trimming.
Any one of the 3 techniques will work.
Message 8 of 12
Here are the drgs
thanks
Message 9 of 12
JDMather
Which one of the three methods above (1, 2 or 3) do you want to have demonstrated with this assembly?
(technique #1 is the easiest for beginners)
Message 10 of 12
in reply to: JDMather
the of course technique #1
Message 11 of 12
demonstrate multi body solids please
Message 12 of 12
rdyson
PDSU 2016
