I have a part I am trying add a threaded hole to. The option for threaded holes is unselectable. I tried editing the registry as past posts have said, but the "parts" folder doesnt show up in the registry. I have been through every folder in the registry and dont see anything that has to do with threaded holes. Not sure what else to do.
Running Inventor Pro 2012 on Windows XP.
Solved by Dennis_Jeffrey. Go to Solution.
Seems to be still an Issue. But this solution worked also well for me.
Inventor 2013
Excel 2010
Windows 7 SP1
Hope someone can help me. i can not add threaded holes and have try the REGEDIT way but no luck (at first there was UseExcelToReadThreadFile so a created one). can some one help.
Window 7
Inventor 15
Do you have excel installed on your machine, meaning you can find excel.exe through WIndows Explorer? If so have you launched Excel at least once?
Mark Lancaster
& Autodesk Services MarketPlace Provider
yes, i have been using excel for same time now. inventor 14 was working just fine but this new inventor 15 its where i have the problem.
