Hello all,
Have a little Head scratcher here. I was using the shaft generator to create a shaft that has a lot of size diameters on it. (see attached image "thread-shaft"). On each end there is a short splined area, and they are common size splines so IV creates them very nicely. Now i have a small area that has a large diameter thread on it. (4-5/8 - 12tpi). In the base thread.xls all the thread sizes stop at 4". That is fine because I have my own thread sheets in the xls for alot of different size non-common type threads. (i.e. Buttress, very large diameter threads 4"-15"). Now, why is it that the shaft generator tool does not read my sheets that i created in the default thread.xls file location?? See attached images from assembly shaft generator & just regular part thread creator. I am guessing that it would read from the same file just like a part?? I must be wrong??? Not sure.... any thoughts??? thanks.
2013 IV Ultimate Design Sut.
i7 3.5G overclocked
W7 - 64bit 12g ram
