Hi there, I can't download "THREAD MODELER plug-in" for inventor 2011.
Is there anybody out there help me to find out why?
Hashem.
Solved by JDMather. Go to Solution.
Solved by blair. Go to Solution.
Do you use Whitworth threadform?
It is pretty easy to create your own iFeature threads.
The CoolOrange Thread Modeler on installs on 2015, 2014 and 2013 versions of Inventor might be the reason.
Hello, Thanks for your suggestion. I am new inventor and autocad user and I am an old machinist too. I didn't take class. I just use up people's blogs and books like yourself to do what I need to do.
I use inventor to create STL files for 3d printing in my machine shop. It is so easier to 3d print some plastic parts rather than to machine a chunk of plastic.
I need to use all sort of threads sometimes, metric, imperial or American's.
Is there any article regarding "thread and iFeature" that is able to help me and keep me to stay far from classrooms?
I appreciate that.
@hnegahdar wrote:
...I am an old machinist too. ...
I also worked out on the shop floor for 8 years as a machinist.
Set up the part with a 60°single point cutting tool - just like on the lathe, and then do a Coil-cut feature. (there is one little trick required in your release)
Because 3D printing is not as precise and machining - you will have to step the tool over and take a second cut as well to give you the clearance you need.
Attach your *.ipt file here for further instruction. (BTW - I don't think that add-in would have given you the geometry you want.)
You are absolutely right about 3D printing that it doesn't do the proper job yet however, i enjoyed 3D print some gears. I've followed your instruction to cut the thread using "coil" command and also printed the part but as you said,I had no choice to pass my bit few times on it on the lathe to make it workable. I've attached the .ipt file as you instructed.
Thanks again.
As you gain more experience - you really should concentrate on fully constraining your sketches.
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Also - you should see if you can find the Service Packs and Updates for 2011.
I'll concentrate more on constraints. I could find inventor 2011 sp1 and sp2 in Autodesk website but I am not sure that I will be able to update by myself.
If it really necessary then I must ask somebody to help me with this.
Thanks again, you've been very helpful, I appreciate that.
Hashem
