Please help, I can't see threaded surface after I had done exercuted thread. Is there any missing softwware that I didn't download? Help is appreciated. Please see the attached document.
Do you have MS Excel installed on this machine and and did you run it at least once before installing Inventor?
Did you install Inventor with anti-virus and UAC turned off?
Is this a new problem - or did it used to work on this machine?
What version of Inventor are you running? Have you installed all Service Packs, Hot-fixes or Updates for your version?
Can you attach the *.ipt file here?
What diameter is your cylinder?
What Specification did you use for the thread?
If you go to Tools>Application Options>Hardware tab, what happens if you set to lowest option?
If you open a threaded part from the Samples/Tutorials files do you see a thread?
If you create a 2D drawing do you see simplified representation of the threads?
Is your graphics card driver up to date?
What are your system specifications?
The CADWhisperer YouTube Channel
Yes, I have MS excel installed, anti-virus is on, but what is UAC? I'm running Autodesk Inventor Professional 2012. The diameter is M12 x 1.75 spec, but regardless of what diameter, still the same problem....
UAC = User Access Control (Windows OS) and could very likely be the source of the problem. (either that or a graphics card driver)
Inventor (especially 2012) should be installed with UAC temporarily turned off during the install.
You didn't answer several other of my questions.
Your part on my machine.
