Ignoring deliberate press fits in an interference check would be very
helpful, but there would probably need to be some means of identifying that
a press fit was intended. It doesn't sound like that would have to be
anything very involved. It might be something like finding them in the
first check, but allowing an RMB so that a click would mark it to ignore in
future checks.
I also see problems with the display of interfering parts. I suppose the
software gets confused during hidden line removal when two parts occupy the
same space. To get a good iso or shaded iso, I often have to reduce the
size of pins or enlarge holes so that the lines do not get scrambled at the
areas of interference. This is not desireable because it is best if I
change those parts back to the true size (relying on memory). It seems like
there should be a way to make the system properly display the parts that are
outermost or closest to the viewpoint. I remember a couple years ago when
using Pro/E this was a continuing problem. Can something be done to improve
this?
Ed R
"Dave Jacquemotte" wrote in message
news:61C670443CCD6A38B8FA7F95F9C7387B@in.WebX.maYIadrTaRb...
> And press-fit interference, too.
