My brain just isn't getting it.
I have a base solid shaft with a keyway in it. I need to shorten the keyway, so I figured move face would do it. But when I select one of the arced faces on the end of the slot and try to move it the best I can do is move the whole slot. Seems counter intutive to me,... I didn't select the whole slot, just the one face. I have tried taking into Fusion, but am even more lost there.
So what am I missing?
Solved by JDMather. Go to Solution.
Sounds like the Key-Way is done with an iFeature, you should look at the table that makes up the iFeature in the part-browser tree.
Turn off Automatic Blending
