Inventor Forum
This should be simple, but...
4 REPLIES 4
373 Views, 4 Replies
My brain just isn't getting it.
I have a base solid shaft with a keyway in it.  I need to shorten the keyway, so I figured move face would do it.  But when I select one of the arced faces on the end of the slot and try to move it the best I can do is move the whole slot.  Seems counter intutive to me,... I didn't select the whole slot, just the one face.    I have tried taking into Fusion, but am even more lost there.
So what am I missing?
4 REPLIES 4
blair
Sounds like the Key-Way is done with an iFeature, you should look at the table that makes up the iFeature in the part-browser tree.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
in reply to: blair
Hi Blair.
The part is a Base Solid.  No features whatsoever.
JDMather
Turn off Automatic Blending
in reply to: JDMather
Thanks JD.  I new it had to be something simple.
