Inventor Forum
This assembly crashes Inventor everytime
4 REPLIES 4
158 Views, 4 Replies
I just saved and closed this weldment. When I went to reopen it, it now
crashes Inventor. I get the "Autodesk Inventor has encountered a problem
and nees to close. We are sorry for the inconvenience." error message.
I put this assembly in the inventor.customer-files newsgroup.
Can someone else try to open it, save and repost.
Kirk
Dell 4550
WinXP Pro
P4, 2.8 Ghz, 1G
Quadro 900 XGL
nVidia v6.14.10.4403
1280x1024, 32 bit
4 REPLIES 4
Same thing here. Even tried rebuilding each part. Crashes in R6 as well.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Kirk A." wrote in message
news:8F1D3FEF372C15A30B8664599767D71B@in.WebX.maYIadrTaRb...
> Thanks,
> Kirk
> Dell 4550
> WinXP Pro
> P4, 2.8 Ghz, 1G
> Quadro 900 XGL
> 1280x1024, 32 bit
Do you save Old Versions? You'll probably need to go back to one that opened and
go from there.
Dave Jacquemotte
Automation Designer
I do, but it did not save an old version on this one.
Is today friday?
"Dave J" wrote in message
news:E2EEE760D582EA8EA6E0AF304DCA4911@in.WebX.maYIadrTaRb...
opened and
> go from there.
> Dave Jacquemotte
> Automation Designer
Thanks, I guess I will have to rebuild it from the ground up. At least I
didn't loose any parts.
"Sean Dotson" wrote in message
news:9F54175EBD3AC4914849E222AEFEE392@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
problem
> > Thanks,
> > Kirk
> > Dell 4550
> > WinXP Pro
> > P4, 2.8 Ghz, 1G
> > Quadro 900 XGL
> > 1280x1024, 32 bit
