Inventor Forum
Thinning of cylindrical objects after simulation
1 REPLY 1
methoni
241 Views, 1 Reply
Is it possible to show the deformed nature of a shaft  after loading along its axis and simulation of the part. If you take as an example a rod of plastecine and stretch it you will see the centre section thinning,the same laws apply to a rod of steel during stretching,why is it that this is not shown during the
simulation of the part,is it mesh settings or something that is not built into the analysis. When one applies loadings to sheet metal the deformation is clearly shown.
Any comments please.
1 REPLY 1
CCarreiras
in reply to: methoni
Hi!
No. Simulation results only gives you a visual scheme of the resultant forces. Does not deform the 3D model.
Even if the force is enough to break the part, it will show you where the part will break (by a scheme of colors), but the 3D model will remain in one piece.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
