I have to print my drawing for my school project, but after I exported it I noticed that some very thick lines we're created where the thread supposed to be. Is there a possibility to remove them? Thank you
Try using the High-Quality setting within the Export to PDF within the Options. The "Standard" settings seems to create problems.
Export to ACad preserving line weights and then use ACad to Export to PDF?
When the "save as" dialog box comes up when you export to pdf hit the options button next to the save button and check "remove object line weights"
You can also edit the line weights in your style library. Or change thread lines (style manager object defaults) to hidden narrow if its not already,etc...
