there is no option where we can apply draft for surface.... this option is there in all the major softwares....
what is the altenate solution for this issue???
Yes there is see the attached.
It is available in several locations.
How much training have you had in Inventor vs these other programs?
It works pretty much the same as in AutoCAD, SolidWorks and Creo (Pro/E).
What other major software are you familiar with where you saw this functionality?
We should also distinguish between surfaces and faces (solids).
dude... i have more than 2yrs exp in autodesk inventor..... i knw in and out of inventor... plz look at the question which i have asked.... i am talking abt SURFACE...... create two surfaces perpendicular to each other and try to use draft, it doesnt work... it works in pro/e CREO.... this is vry vry important when am working with mold design (parting surface creation).....
look at the screenshot and understand the question which i have asked.....
Hi shuaib_cad,
Does the taper option shown in this image get you what you're after?
I hope this helps.
Curtis
Are you trying to do this manually? There is a whole Mold environment for this and with a little adjustment I can get a runoff surface to orient the way I want.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
dude... its not as simple as u are thinking.... i have more than 50 surfaces which is patched and stitched..... at the end of the day i want to apply draft for 5 or 6 faces.... it can not be done initially using the extude taper option....
am working on pattern plate creation for casting part..... is there any other solution??
dude?
I'm not thinking it's simple. I just asked if that option helped with your goal. So far the details you've provided are a bit scarce. You might consider posting a screen shot or example file of what you're working on so that others can more effectively help you.
I hope this helps.
Curtis
images attached... the red color surface is where i want to apply draft....
@shuaib_cad wrote:look at the screenshot and understand the question which i have asked.....
This is trivial.
I suspect your screenshot does not reveal your true problem.
Attach your real problem (ipt file) here.
You should be able to get any trimmed planar surface at any angle you want.
Other surfaces are a bit more challenging, but without the real file....
@shuaib_cad wrote:images attached... the red color surface is where i want to apply draft....
This looks pretty simple.
Attach Inventor file here rather than images.
Do you have access to Inventor Tooling?
That's still an image file, not a part file.
dude.... this is vry vry confidential...cant attach the ipt file.... sorry....!!!
anyways my question is not answered.... y there is no draft option for surface....???
it should be added.... its available in all the other softwares...
Should be trivially easy to create a dummy example that doesn't give away any proprietary information but exhibits all the same behavior.
Even if you can't directly draft a surface like you can a face, it should be trivially easy to work around (especially for the planar surface you have pictured).
shuaib_cad wrote:
...it should be added.... its available in all the other softwares...
This is a peer-to-peer help forum.
The Inventor Wish list is over here http://www.augi.com
There is also a direct Autodesk link if you would like for me to look it up for you.
dude what u are seeing there is only a 1% of the whole project....
i have done the draft using manual options only (like deleting the face using 3d sketches to project the edges and patching it)....
its done.... but am looking for an easy way to do this.... it took a hell lot of time.... if there was an option for this it could be done in seconds....
I suspect there is a trivially easy solution - but you will have to make the effort to create and post an example that exhibits all of the behavior of your proprietary data.
