Inventor Forum
The Selected component has no volume
2 REPLIES 2
4852 Views, 2 Replies
I tried to import an stl file into inventor 2013 and it worked. I now have that ipt file that I ahve attached to this thread. The only problem is that now I cannot manipulate my solid (i.e. put holes in it).
Has anyone run accross this problem or have any idea what needs to be done?
Khash
2 REPLIES 2
wilkhui
Hi Khash,
Thanks for your post - you won't be able to perform those solid operations since the .stl is a mesh.
There's a plug-in on the Labs site (link below) that will allow you to convert this to a Base feature, if you install that then you should be good to go 🙂
Hope this helps!
Indy
http://labs.autodesk.com/utilities/inventor_mesh/
ConvertToBase
Inderjeet Singh Wilkhu
Product Owner - ASM
KevinLi-Autodesk
in reply to: wilkhui
Hi Khash,
Just add one comment, not only STL mesh but also for CATIA V5 cgr mesh data and JT mesh data, this addin (Inventor Mesh Enabler) tool can also convert mesh data to solid or composite.
Kevin Li
Quality Assurance Team
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
