Tried repair, tried reinstall.
This one popped up after I upgraded from MS Office 2007 to MS Office 2010.
Any ideas?
Rusty
Solved by DannyHubbard. Go to Solution.
Solved by LT.Rusty. Go to Solution.
LT.Rusty
I think it has to do with Microsoft Access drivers not supporting 64B or something like that. See this link: https://social.msdn.microsoft.com/Forums/vstudio/en-US/ebb05600-055a-44c4-8cd3-d33a79878b23/error-wh... Locate the reply from Yoyo Jiang and it indicates how to resolve your issue.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Well, here's the problem with that fix:
64-bit version doesn't coexist with MS Office, and the 32-bit version doesn't solve the problem.
I may just have to uninstall PDSU and re-install it on Monday. Bleh.
Rusty
LT.Rusty,
If a different person (Administrator) logs into your machine with their windows credentials, do they receive the same error message?
Thank you.
@Anonymous wrote:
LT.Rusty,
Thank you.
Yes sir - same result, different administrator login.
Rusty
LT.Rusty,
After speaking to some of our development staff is has been suggested that what probably needs to happen is a reinstall of Microsoft Office so that the Access components is registered correctly. Or you could probably just install the Access Runtime, http://www.microsoft.com/en-us/Search/result.aspx?form=MSHOME&mkt=en-us&setlang=en-us&q=access%20run...
Please try this and send us an update.
Thank you.
Doesn't work.
64-bit Access runtime won't coexist with 32-bit office, and 32-bit runtime didn't do it.
It's odd, really - I've used this same 32-bit Office installer on two other computers (Pro Plus, 5 licenses, not pirated! 🙂 ) that also have Inventor 2015 installed on them. No problems with any of them. Only problem is here when it upgraded from 2007 to 2010.
Rusty
Well, in the end the problem went away after a complete uninstallation and reinstallation of PDSU. Uninstalling and reinstalling just Inventor and all relevant add-ins didn't do it.
So, at least it's fixed. I hadn't wanted to kill off a day doing that, but at least I had enough other things to do that I could afford to leave my computer tied up and not lose time on projects.
Rusty
I installed Office 2007 and Inventor 2015 with the Electrical Catalog Browser from the Product Design Suite.
Then I went to install Office 2010, I had two options uninstall Office 2007 complete to install the Office 2010 64-bit or uninstall the Microsoft Access database engine 2010 64-bit and install Office 2010 32-bit. I choose to just uninstall the Access database engine 2010, then I installed Office 2010 32-bit with the Upgrade option.
Now when running Inventor 2015 I get the same error you are seeing with the Microsoft.ACE.OLEDB.12.0 not registered.
So I went back to the Product Design Suite media and installed the Microsoft Access database engine 2010 64-bit again from ...3rdParty\x64\AceDataEngine\AceRedist.msi .
Now when running Inventor I not logger get this error and the Electrical Catalog Browser is present in Inventor. Also I haven't seen any issue with the Office 2010 products.
Danny
Danny
Hm. I didn't install the copy of Access database engine that came with Inventor - I didn't actually know where to find it at. I used the Access database engine downloaded from Microsoft found in one of the early posts in this thread. I got an error about not being able to install it with Office 32 bit.
Looking again at Control Panel --> Programs and Features I see that there is a new copy of Access DB Engine installed yesterday, which presumably coincides with my reinstallation of PDSU, so ... I guess that was the solution. My way worked, but your way would have been a lot quicker for the same effective result.
Thank you!
Rusty
We just solved this issue by following this link:
Our issue happened after installing Office 365/Office 2016, which removed MS Access.
To resolve this, we went to the download/media drive and searched for:
AceRedist.msi
<Media Drive>:\3rdParty\AceDataEngine\AceRedist.msi
Upon running that MSI file we chose the 1st option, which was to reinstall /Repair
