Hello
Somehow my IDW location box is got empty while placing the view in Inventor 2012.
Please advise is it any setting responsible for that?
I wouls like to return it back to normal
http://screencast.com/t/dQTrYWC9XjP
Please help
Orest Yavtushenko
Solved by Curtis_Waguespack. Go to Solution.
did this just start happening?
have you tried to restart your computer?
have you tried to update your graphics card driver?
Hi Orest_iy,
Here is something to check, but I'm not sure if it would result in what you're seeing.
If you go to the Tools tab > Application Options button > Drawing tab > Show Preview As setting is it set to All Components or something different?
I hope this helps.
Curtis
Curtis
Yes it was bounding box there.
Thank you for avice!
It work ok now
Orest
