Hi all, I've just uninstalled all the factory Design Suite 2014, performing a clean uninstall and install a new FDS 2015.
No autodesk product is launching succesfully. Inventor, Autocad, Autodesk 360, ecc give me the error "The application failed to initialize properly (0xc0000022). Click on Ok to terminate the application". OS is Windows 7 x64 correctly updated. User have Administrator privileges.
I tried to repair, uninstall, clean and reinstall, but have no success.
Searching in google I've found some old discussions but nothing repair. I've launched several times in command mode the application "sfc /scannow ", uninstall Macrmedia Flash player, reboot the system. No success.
Can anybody help me?
Hi! Based on the behavior you described, it sounds like there are some runtime libraries missing on your machine. Could you take a snapshot of the following and send it to me directly (johnson.shiue@autodesk.com)?
Control Panel -> Programs -> Programs and Features -> scroll down to where you see Microsoft Visual C++ 20xx Redistributable at the top.
Thanks!
As Johnson suggested, have you tired rebuilding your VC++. Do let us know, if the problem persists. I will be happy to help.
Good morning Vinod, Johnson is helping me, but all he suggest don't solve this trouble. If you send me a mail or give me your address I will be happy to include you too in our discussion.
Thank you.
Can you please check the following suggestion and let me know whether it helps.
Hope that helps.
My heart is crying, but last weekend I've formatted my PC. Probably Windows 7 corrupted, given that I wasn't be able to install Inventor Publisher 2015 too.
Thanks to all help me!
I feel very sorry for your situation. We will definitely try to assist you as much as possible to get you going with the software. Can you install from a new Win 7 deployment and let me know a convenient timing for a remote session to install both Inventor and Publisher 2015 on your machine.
Looking forward to your reply.
Are you still facing the issue. let me know, if I can help further.
Hope everything is okay and you were able to use your 2015 products.
Just checking on whether you still need help or were you able to get through with your 2015 products. Let us know, if you need further assistance. I will be happy to help.
