Inventor Forum
That's twisted, man..
4 REPLIES 4
214 Views, 4 Replies
Yea, that's the new one they're using these days. In my day, the
saying was "That's cool".
What's not cool is my attempt to create a loft between two concave
sections and the outcome is a twist or an added facet where there
should only be a smooth transition. I've checked the sketches and they
are closed loops, fully constrained and inventor says they are happy
(no +). I've uploaded the file loloft.zip to the CF area. Can someone
take a look at this file. See the engineer's notebook in the file for
more comments.
-Jon G.
Jon Genova
Senior Mechanical Design Engineer
BioServe Space Technologies
A NASA Commercial Space Center (CSC)
genovaj@stripe.colorado.edu
Bioserve URL http://www.colorado.edu/engineering/BioServe/
Personal URL http://stripe.Colorado.EDU/~genovaj/
4 REPLIES 4
Point Mapping should fix it.
"Jon Genova" wrote in message
news:3DD557E4.128749D9@stripe.colorado.edu...
> more comments.
> Thanks,
> -Jon G.
> Jon Genova
See CF under yours, you need to add rails, all this stuff is new to me I
just fiddled with your model . Some one will post a better solution. Rails
stop the loft twisting, the best way to make em though I not sure.
Laurence,
Power is nothing without Control
> more comments.
> Thanks,
> -Jon G.
> Jon Genova
Hi, Jon.
I'd use point mapping instead of rails to correct your problem. Rails will
"force" the shape and point mapping will correct the twisted surfaces while
still allowing a relaxed progression between profiles. I'm not that familiar
with the procedure, but I've found it easiest to clear the Auto checkbox,
delete all the existing point sets (select and press ) then go back and
add mapping sets. Pay attention to the values so you are sure you've hit the
end of the curve (think you should get a green dot on vertex, but it's hard
for me to tell).
I don't know what your intentions are, but have posted another method in CF.
If you don't need the specific shape at Sketch2, I'd just loft between the
extrusion and Sketch1 with a tangent wt of .1 or .2 on the Edges profile. You
might try playing with it and see how close to the desired shape you get.
Jeff
more comments.
-Jon G.
Jon Genova
Good information. I'll check out the posted files this weekend.
Thank you for your time, gentlemen.
Jon Genova
