Inventor Forum
Texture with transparence
15 REPLIES 15
Message 1 of 16
TONELLAL
1436 Views, 15 Replies
I cannot create transparent textres with Inventor 2014 !!
Old version (before Inventor 2013) : use an image named "<xxx>&.bmp", the bottom left pixel determine the transparent color. This was functionning before 2013, and it is functionning now with 2014 :
New method (since Inventor 2013) : use a black and white image as "cutting texture" : on the preview it's ok, but does not function...
Where is the problem ?
-graphic drivers are up to date and approved
-same problem with all workstations
Any ideas ?
15 REPLIES 15
Message 2 of 16
ChrisMitchell01
in reply to: TONELLAL
I'm not in a position to actually test this right now - have you tried adding the & symbol into your image file name ?
-Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 3 of 16
TONELLAL
in reply to: ChrisMitchell01
It seems it functions :
-only with Autodesk texture files
-only if you have a texture file and a cutouts file, which are named "xxx" and "xxx_cutouts".
On the preview it is only correct, you can use (or not) whatever you want as image and whatever you want as cutout.
See joined files :
Textures1.png : texture = cutout = adsk cutout
Textures2.png : texture = adsk txture, cutout = adsk cutout
Textures3.png : no texsture, cutout = adsk cutout
Textures4.png : texture = cutout = adsk texture
Textures5.png : texture = custom texture, cutout = custom cutout
Textures6.png : no texture, cutout = custom cutout
Message 4 of 16
Xun.Zhang
Hi TONELLAL, For your problem, actually the Cutout style can only be rendering in Realistic visual style, in other words, in Shaded visual style, the transparence is out of service. but, a Good news is Cutout in shaded visual style has been enhanced in Inventor 2015 release, you can have a try. And there is a workaround for your reference. 1. Continue using legacy BMP image, such as attachment (the image should have a suffix &) 2. set the image to both Cutout and Generic images setting Then, the rendering in Shaded mode which is as expected Notice: if change the scale of cutout, please change scale from texture editor for both Generic and Cutout setting to make them consistent.
Xun
Message 5 of 16
TONELLAL
in reply to: Xun.Zhang
All the samples I sent are in Shaded mode, not Realistic mode.
Standards appearances, like "Deployed metal", function in all display modes (apart wireframe) see joined file. Perhaps arer there particular rules to function ?
Message 6 of 16
Xun.Zhang
Hi TONELLAL,
Yes, you are right. The five default Cutout appearances are supported as you pointed out, but most of customized cutout appearance, the support is limited in Shaded mode which was enhanced in Inventor 2015. Please have a try if you are interested.
Xun
Message 7 of 16
TONELLAL
Ok, last question : how can I see through the part (old option "see internal faces") ? Even in realistic mode it seems impossible in 2014...Textures8.png
Message 8 of 16
Xun.Zhang
Hi TONELLAL, Sorry for a bit later response, check with the option, it's not listed in new editor which means the option probably removed in the dialog. Sorry for that... There is an workaround to enable it in your side with VBA, please let me know if it's doesn't work in your side.
Sub SetInteriorFacesVisible()
Dim oDoc As PartDocument
Set oDoc = thisdoucment
Dim oRenderStyle As RenderStyle
Set oRenderStyle = oDoc.ActiveRenderStyle
oRenderStyle.DisplayInteriorFaces = True
End Sub
Xun
Message 9 of 16
TONELLAL
Ok, it function... but it could be very simple to have a check box in the Appearances editor !
I've created an IdeaStation : http://forums.autodesk.com/t5/Inventor-IdeaStation/See-interior-faces-in-appearances/idi-p/5225871
Message 10 of 16
RobJV
Seems like you got things working.  Pay special attention to this: http://forums.autodesk.com/t5/inventor-general-discussion/cutout-appearance-doesn-t-work/td-p/362747...
See my answer on second page.
Rob
Message 11 of 16
a.elezi00
in reply to: RobJV
I don't understand why the same file in Inventor2014 appears correctly: Capture1.PNG
but in Inventor 2016 not:
Is there any view setting to avoid the double view effect?
Message 12 of 16
Xun.Zhang
in reply to: a.elezi00
Hi a.elezi00,
Is it possible to provide your file to me for more investigation, my email: xun.zhang@autodesk.com. I will get it back to you once research complete.
Thanks again!
Xun
Message 13 of 16
mmoucka
Good Mornin masters.
I have a question about cutout texture in VBA. I have not found a parameter in RenderStyle, which define cutout texture full file name.
How and where is this parameter ? Can You help me ?
Thanks.
Tags (2)
Message 14 of 16
mmoucka
in reply to: mmoucka
Nobody know ??? Realy ?
Message 15 of 16
Xun.Zhang
Hi mmoucka,
Sorry, we don't support it anymore in API for cutout property editing.
Xun
Message 16 of 16
mmoucka
And can I ask You why ? Man Sad
And will it be ever supported again ?
Thak You.
