Inventor Forum
Text thickness
3 REPLIES 3
712 Views, 3 Replies
Text thickness
For our client we need to convert our Inventor drawings to AutoCAD. But when I do so the text, where a symbol is added, becomes a multiline (which is logical) but also thicker.
Is there a way to prevent it? Because manually changing those lines in every drawing will take up a lot of time.
Below you will find an example.
Job
3 REPLIES 3
blair
Inventor does use a "DWG Template" for the conversion process to develop your DWG file. You can edit this file or have multi files for different exports. Not sure if you will be able to get what you want or it's just using the "closest match" for that portion.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
in reply to: blair
I have accepted the fact that I wont get the result that I want.
fakeru
Is this Simplex font? For me this doesn't happen.
I use a configuration .ini file with following settings:
[EXPORT SELECT OPTIONS]
AUTOCAD VERSION=AutoCAD 2010
CREATE AUTOCAD MECHANICAL=No
USE TRANSMITTAL=No
USE CUSTOMIZE=No
CUSTOMIZE FILE=C:\Users\Public\Documents\Autodesk\Inventor 2014\Design Data\DWG-DXF\FlatPattern.xml
CREATE LAYER GROUP=No
PARTS ONLY=No
REPLACE SPLINE=Yes
CHORD TOLERANCE=0,001000
[EXPORT PROPERTIES]
SELECTED PROPERTIES=
[EXPORT DESTINATION]
SPACE=Model
SCALING=Geometry
ALL SHEETS=Yes
MAPPING=MapsBest
MODEL GEOMETRY ONLY=No
EXPLODE DIMENSIONS=No
SYMBOLS ARE BLOCKED=Yes
AUTOCAD TEMPLATE=
DESTINATION DXF=No
USE ACI FOR ENTITIES AND LAYERS=No
[EXPORT LINE TYPE & LINE SCALE]
LINE TYPE FILE=C:\Users\Public\Documents\Autodesk\Inventor 2014\COMPATIBILITY\Support\invISO.lin
Continuous=Continuous;0,
Dashed=DASHED;0,
Dashed Space=DASHED_SPACE;0,
Long Dash Dotted=LONG_DASH_DOTTED;0,
Long Dash Double Dot=LONG_DASH_DOUBLE_DOT;0,
Long Dash Triple Dot=LONG_DASH_TRIPLE_DOT;0,
Dotted=DOTTED;0,
Chain=CHAIN;0,
Double Dash Chain=DOUBLE_DASH_CHAIN;0,
Dash Double Dot=DASH_DOUBLE_DOT;0,
Dash Dot=DASH_DOT;0,
Double Dash Dot=DOUBLE_DASH_DOT;0,
Double Dash Double Dot=DOUBLE_DASH_DOUBLE_DOT;0,
Dash Triple Dot=DASH_TRIPLE_DOT;0,
Double Dash Triple Dot=DOUBLE_DASH_TRIPLE_DOT;0,
Try it.
Autodesk Inventor 2015 Certified Professional
