Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Text scrunched when exporting IDW to PDF-IV 2014
3 REPLIES 3
gcross
428 Views, 3 Replies
Does anyone have a solution for text appearing scrunched together when exporting an idw to PDF in Inventor (see IDW & PDF examples attached)?
Text in the Table Style is ARIAL, .100" height with a 75% stretch.
It looks fine if I print to Adobe PDF but not if exported to PDF.  I prefer to export rather than prnt if possible.
Gary
Tags (3)
3 REPLIES 3
Paul-Mason
in reply to: gcross
There was a similar problem to this posted some time ago - I think it was fixed in a hotfix or Sp
Are both IV and Adobe updated with SP's Fixes and updates also can you or are you allowed to post the file that your having this issue with or creat a simple example file if your not allowed to post the original
I use the export to PDF a lot, but I use nothing other than Times New Roman with out any problems.
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
blair
in reply to: Paul-Mason
I might try without the 75% stretch, or try using the High-Quality setting in the Options when doing the export to PDF
Delta Tau Chi Ī”Ī¤Ī§
gcross
Mason-Paul,
It seemed to correct itself after I updated the Adobe Acrobat.
Thanks all for replies.
Gary
