What is likely the case is that your background color is black and your text is very dark. This is the issue I have also. What I do to fix this, with limited results, is to change the color of the dimensions to "by layer'. This can be done through the dimstyle manager. Once you find which style is the imported style, you can then change the text color to whatever you want.
Thom
