Inventor General Discussion
Distinguished Contributor
10 Kudos
Post 1 of 3
Text placement default on create view
101 Views, 2 Replies
05-14-2012 07:49 AM
When creating views in Inventor 2013 the text displayed for example VIEW001 (1:1)VIEW 001 is placed under the view by default. I would like this to be above the view by default, could anyone tell me how to do this ? Thanks in advance
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
Hi Anthony,
In a drawing go to the Manage tab > Styles Editor button then expand the Standards node in the left pane and choose your standard, then on the right pane choose the View Preferences tab. In there you'll see a Position option, choose between Above and Below.
I hope this helps.
Curtis
1,702 Kudos
Post 2 of 3
Re: Text placement default on create view
05-14-2012 08:31 AM in reply to: Anthony
Hi Anthony,
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
10 Kudos
Post 3 of 3
05-14-2012 08:58 AM in reply to: Curtis_Waguespack
Hi Curtis, cheers for that, it worked great, just what I was looking for.
:smileyhappy:
