When creating views in Inventor 2013 the text displayed for example VIEW001 (1:1)VIEW 001 is placed under the view by default. I would like this to be above the view by default, could anyone tell me how to do this ? Thanks in advance
Solved by Curtis_Waguespack. Go to Solution.
Hi Anthony,
In a drawing go to the Manage tab > Styles Editor button then expand the Standards node in the left pane and choose your standard, then on the right pane choose the View Preferences tab. In there you'll see a Position option, choose between Above and Below.
I hope this helps.
Curtis
Hi Curtis, cheers for that, it worked great, just what I was looking for.
