Inventor Forum
Text embossing question
4 REPLIES 4
917 Views, 4 Replies
I am making an ID tag that will be welded to a 12 sided tapered steel pole. I have to bend the tag to fit the pole. That part I can handle. I haven't had any trouble with embossing before but I haven't had to deal with a polygonal object either. As you will see in the attached screen shot I need to emboss the text onto the tag and have it stay true to the bends. I'm sure I can find a work around but it would be great if I didn't have to. Any help will be greatly appreciated.
Lloyd Tilley
Inventor 2014
4 REPLIES 4
Cadmanto
Have you tried using this command?
Also, here is a link to a thread you might find useful.
http://forums.autodesk.com/t5/Inventor-General/Projecting-a-text-on-to-a-curved-surface/td-p/2378524...
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
JDMather
@Anonymous wrote:
I am making an ID tag...
You might modeling it in folded form as sheet metal part.
Then run Unfold and use whatever tools needed to create design.
Then Refold and finally Flat Pattern if needed.
Can you attach the file here?
mpatchus
For this example I used a 12 sided taperd pole 6' long 8" AFF at bottom, 5" AFF at top.
Using the bend command after the emboss was created allowed me to achieve this.
I've attached the part (INV 2012) for you to examine.
This is one way to do it, there are probably other methods as well.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Thanks Mike. That worked great. I appreciate it.
