Problem-
I would like to find a way to edit multiple text boxes in inventor instead of one at a time.
For example, in autocad, when multiple text boxes are selected, any values that are different in the properties window are represented as "varies".
Is there a way to select multiple text boxes and do things such as change the text height, justification, font, etc, just as it works in autocad?
Solved by cbenner. Go to Solution.
Text editor improvements are one of the oldest and most requested enhancements to Inventor. That said, if you set up a particular style, using the style editor on the Manage tab, you can select several text boxes at once (using ctrl select) and set them all to that style (Annotate tab all the way on the right end). Whatever settings you put in that style will go out the the text boxes you selected.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
