How can I ensure that text appears on top of a filled area when created in a sketch?
I found when I moved to IV 2014 that text was disappearing from my title blocks when I reopened drawings.
I have played around with text and filled areas in sketches, and symbols.
I find that when opened and reopened, some times the text is obliterated sometimes not and somtimes partially.
Text ok when added on top of an existing sketch in an idw.
W7-64 pro Quaddro 2000 (latest driver)
I can't reproduce it from scratch, maybe some key steps are missing. Could you attach the dataset or provide more details?
I have just retried to reproduce it myself. What I found was that in making a test symbol and a title block, text was covered by a filled area and not by a hatched area. This time.
I then opened a new idw and immediately created a sketch. Initially fill obliterated text. Then when I moved text and sketches arround, sometimes the text came to foreground, sometimes background.
Also some partial obliterates. See attached.
Text created outside the sketch environment always seems to be in the foreground.
It seems that predominently Fill obliterates Text in IV2014.
Is there a way to control the draw order? A control to move Fill to the back and text to the forground?
Not got any help on this problem. I have numerous title blocks that are affected that have to be modified when ever accessed. Time consuming. Title blocks I have used for years. Problem only appeared when I upgraded to IV2014. Is there a control to bring text to front?
When taking the same workflow in R2013, the same behavior happens. Now there is no control or option to bring the text to front or back. And one issue DID 1500725 has been logged in our tracking system.
I am really interested that what is the behavior from your side in the previous release before R2014. Could you provide some more details about that?
Many thanks for you to continue providing the comments on this issue! I am keeping investigating this issue, finally I got the difference between R2013 and R2014. Please see the attached image for the behavior. We could see the text in R2013, although the text is behind the hatch. But it disappears in R2014.
Is that what you concern much? This should be an unexpected behavior here, and we will look into this.
Many thanks for you to report this issue to us!
One issue has already been tracked in our database, and it is being investigated now. And we got one workaround - It will work fine when changing the graphics setting "Performace" within Application options -> Hardware dialog to "Compatibility". Please have a try.
Hope it helpful for you!
I'm using Inventor 2021 and having this problem. I created a solid hatch and put text overtop. It looked beautiful! Then I deleted another view unrelated to the view I created the hatch and text in, and my text disappears behind the hatch and I can't get it back to the front. AutoCAD has had the "DRAWORDER" command since before Inventor was even around. It's been over 20 years (almost 8 years since this issue was posted), and Inventor still doesn't have a DRAWORDER like command? Is there another workaround? ...because the "Performance" setting didn't do it in my graphics settings.
Hi Brent,
I am not sure if the behavior you are seeing is the same as the original issue. Based on the prior discussion, it looks like a graphics issue. But, your seems to be related to hatch. I cannot seem to reproduce the behavior on 2021.3. Have you installed 2021.3? Please share the files that exhibit the behavior.
Many thanks!
