Inventor Forum
text alignment
3 REPLIES 3
paul_pearson
388 Views, 3 Replies
text alignment
Hi
I have text in a circular shape but how do i place the text inside the part on to the front of the face?
Paul
Inventor 2013
3 REPLIES 3
JDMather
in reply to: paul_pearson
You could have used the inside arc rather than the outside arc.
In either case, enter the Offset Distance.  (edit the sketch and double click on text)
-niels-
you could delete the constrain from the outer circle, making it normal geometry instead of projected, and then dimension the circle so it's on the inside.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
paul_pearson
in reply to: -niels-
Thank you
