Inventor General Discussion
Active Contributor
paul_pearson
Message 1 of 4 (150 Views)
text alignment
150 Views, 3 Replies
07-16-2013 04:02 AM
Hi
I have text in a circular shape but how do i place the text inside the part on to the front of the face?
Paul
Inventor 2013
You could have used the inside arc rather than the outside arc.
In either case, enter the Offset Distance.  (edit the sketch and double click on text)
you could delete the constrain from the outer circle, making it normal geometry instead of projected, and then dimension the circle so it's on the inside.
JDMather
Message 2 of 4 (144 Views)
Re: text alignment
07-16-2013 04:14 AM in reply to: paul_pearson
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
-niels-
Message 3 of 4 (139 Views)
Re: text alignment
07-16-2013 04:18 AM in reply to: paul_pearson
Using IV2014 Pro SP2 - upd.1, Win7-64bit
Active Contributor
paul_pearson
Message 4 of 4 (100 Views)
Re: text alignment
07-16-2013 09:03 PM in reply to: -niels-
Thank you
