Inventor Forum
Tendon motion simulation in Autodesk Inventor
2 REPLIES 2
EliadCohen
315 Views, 2 Replies
Hi all,
Can anyone please recommend a way of simulating tendon driven motion using Inventor?
Basic setup is wire going through a slab. Wire is fixed on one or both ends to slab. Wire contracts (fixed on both ends) or gets pulled on (fixed to one end).
Green part is the slab (soft rubbery) black is the wire/tendon which can contract or be pulled on one side.
Thank you for your time
2 REPLIES 2
JDMather
in reply to: EliadCohen
Can you attach your assembly here?
You can probably do some animations, but if you are expecting to do some bending, compression analysis - you won't be able to do that with the Inventor analysis tools.
EliadCohen
in reply to: JDMather
Assembley packed attached.
If I do need to analyze some bending and compression is there a work around or a recommended way?
Thanks 🙂
